Free VPN for iptv streaming devices,pros&cons
  • I am using Nord VPN for several years on my streaming devices,much to my satisfaction.
    However ,as i only use it for the streaming device i am using,its a relative expensive service.
    I am looking for a free vpn.
    I would like members to give their opinion on the wide range of free VPNs,as are available in Playstore and Formuler Market,the quality of protection,while streaming and other potential pitfalls.
    TIA
  • Paid vpn's are always better and more speed and better secured. Also almost don't save log files.
    I follow your thread, but it's highly likely that free vpn's so much used by other users and they should have a lot buffers.
    Maby it's only fine to search the web with it, but not for streaming...
    You can delete nordvpn already and search in playstore for free vpn's.
    And try them one by one! Only install one vpn on your box and test then. Don't install more then one!!
    Beware that you also need at some vpn's a username/email and password.
    Edited once, last by Lucky13 (March 11, 2026 at 10:30 AM).
