Change Portal URL without starting over
  • Hi All, I am struggling to find this issue when I search, so please feel free to point me to the right thread if possible!
    Every time I change the URL for one of my portal sources, MyTVOnline3 essentially makes me go through the Live/VOD/Series setup all over again. Is there a way to edit the content source without having to start over?
    Thanks!
    Thanks!
    No, so it is now...
    ...if you change dns/url.
    Portal connects to new dns and it ask the same questions yes if you want some groups or not.
    Nothing to do about it.
    Maby a tip for future update of mytvonline3?
    I don't know, but it's now for years now.
    And since end 2025, a lot of dns were blocked till this day.
    So don't do to much...
    ...dns's will be blocked by netherlands, Italy, france, spain etc...
    Goodday my friend
  • Lucky13 thanks for the response. Look like this is a feature that should be made available in a futue release.
    The URLs from my IPTV provider keeps get blocked by cloudflare, but they're generally good at supplying a alternate which means I have to keep resetting my portal.
    Set yourPrivate DNS to QUAD9:winking_face:
