Formuler Z10se VOD channels not saved after the first load?
  • Hello everyone, I bought a Formuler Z10 SE decoder with the ****** portal already installed. I added a second portal, *******, and I'm encountering the following problem: When I launch this new portal, I see the loading bar, and after loading, I see the TV channels. When I press the VOD button, I see a loading bar for movies and series. If I switch portals or turn off the decoder, am I forced to repeat this process? I didn't have this problem with the portal that was originally installed. And the provider tells me that everything is normal on their end. Why isn't the VOD content saved after the initial loading? Thank you in advance for your answers.
  • Hello everyone, I bought a Formuler Z10 SE decoder with the Foxx portal already installed. I added a second portal, Gofluxtv, and I'm encountering the following problem: When I launch this new portal, I see the loading bar, and after loading, I see the TV channels. When I press the VOD button, I see a loading bar for movies and series. If I switch portals or turn off the decoder, am I forced to repeat this process? I didn't have this problem with the portal that was originally installed. And the provider tells me that everything is normal on their end. Why isn't the VOD content saved after the initial loading? Thank you in advance for your answers.
    Hi, hast more effort if you post in right treat. You posted MOL+ for Android and have a z10se.
    I don't have answer for your case.
    Have nice day
  • Moved into right forum.
    First, please never post names from Provider or url`s to them, we do not allow it here on forum! Please read forum rules, thx.
    Does it load each time again and again? This should happen on first loading and when refresh is initialised. Please check how much free space is available and delete all caches from Apps.
