Since last night I have been experiencing a connection error on my device. The message shown is:
“Connection Failed – Please check your internet connection and portal URL (Code: 1010).”
I am using a Formuler Z12 Ultra, and this issue started suddenly without any changes on my side.
To troubleshoot, I have already:
- Cleared the app cache
- Performed a factory reset on the device
- Restarted my internet connection/router
- Reconfigured everything from scratch
Despite all of this, the error persists.
I also tested my list on another player, and it works perfectly fine there, which makes me believe the issue may be related specifically to the Formuler or its configuration.
Could you please advise on what might be causing this issue or suggest any further steps to resolve it?
Thank you,
Tiago
