Would not being able to play anything in Catchup even though the listings are availabe with the date, time and catchup icon only be a supplier issue? When I select a program in catchup everything seems correct , brings up the program title ,duration and looks like its going to play but just a spinning circle. I have 2 suppliers on the same Z12 and the other one works. Logically it is a supplier issue but want to make sure there is nothing I can change to make it work. Thanks
