RugbyPass TV not working
  • I love rugby, so I watch RugbyPass tv, but the online login doesn't work
    It gives me a numerical login or a Q-code, but although I'm logged in the App doesn't register, just says I'm logged out
    Is this a known thing please?
    Maby you need new version?
    What kind of color has the app logo? And what is the exactly name of the app. Maby you know the android package name?
    And in which country do you watch?
    Maby i can create or search a new one for you?
    Is it a orange logo with games and scores? Please tell me
    Please make photo and answer my questions.
  • It was my VPN, I turned that off and it worked, thanks for your help
    Good job my friend!
    Note: open your vpn and search for "splittunnelling" option.
    If you find that option, you can add that app in it. Then you can use vpn, but due the app is splittunneled it won't use your vpn.
    That's why the create splittunnelling.
    Try it.
    Maby nordvpn? In settings you find it direct. Include rugby in splittunnel and save.
