The Z12 BT offers the possibility of programming the Color Keys to connect directly with apps. I did this, it worked, but just a day later it doesn't. Instead I'm getting the remote's search screen, or just nothing. And yes, I have installed new batteries. Any good advice?
BT3 Hot Keys Color
- Apps
- Z12 Ultra
Knor -
July 1, 2026 at 11:03 AM
If it won't save your keys, is that after a reboot or standby?
Im on holiday, so can't reproduce it.
If it's to reproduce, it can be a bug.
henkie can you try to add app to one of your colored keys? And theb try standy and reboot.
Did it save the key and the app you setup at it on your side?
Thanks in advance.
Goodday
Display More
Thanks in advance.
Goodday
Enjoy your holiday!🌞
Thank you my friend Belgiumuser.
Maby can you test it too if you got Z12 my friend.
Wish you a good day my friend and thank you again.
Many can you test it too if you got Z12 my friend.
Hi, I just testing if I can reproduce. I have link the red button to speedtest app. It only works on the Formuler Homescreen and not within MOL4 because the button has other function's . After turn off and restart it still works as linked before.
Wish you a nice evening 🌆
Yes correct, it's only on Formuler homescreen to start an app with a colored button.
Did it worked also after you did standby the box? And after full shutdown of the box?
Cause that was his question. It didn't save the buttons he said, after standby.
In mol4 they are reserved for that app ofcourse.
Did it worked also when you did standby the box? And after full shutdown of the box?
It is saved after standby too.
