When I turn on my TV and then former box shows up HDMI disconnected then have to plug out the power cable from z11 box to get it to work, I’ve changed the cable several times and still the same issue any advice?
Power issue
- Z11 Pro MAX
- Hardware
SdbQqq -
July 4, 2026 at 10:50 PM
Maby the hdmi handshake between your tv and box isn't okay.
Did you turn off hdmi-cec on box and tv?
Do you use official hdmi cable?
Did you try other hdmi port?
Did you already tried latest update? And or beta update? 1339 code in software update? Please try first-->
ThreadFirmware v. 11.3.7 Hotfix Beta and MYTVOnline 3 v 12.1.42 BETA for Z 11 Series released
BETA Software Update for Formuler Z11 Series released.
Firmware Version : 11.3.7 HOTFIX BETA
MYTVOnline 3 Version : 12.1.42 BETA
WARNING:
If you don`t want to test, please wait until official comes out. No Forum support in other threads if beta in use, beta issues…Z11 Series Update
SAMJune 30, 2026 at 1:20 AM Did you tried a factory reset once?
Please be more specific please.
Maby other hdmi port is already fine. And it's not the power adapter.
Let us know my friend. Goodday
Tried all that still the same with factory reset
Factory reset, other same power adapters, other hdmi cable and ports and still the problem exist?
Do you have warrenty?
Can you test it on a computer screen with hdmi connection and other tv?
If it works on a computer screen and or other tv you can exclude the problem.
Yes 2 years warranty
Is hdmi-cec on or off? On your tv and your box?
can you answer the 2 questions please?
For the hdmi-cec settings on tv and box?
And already tested on computer screen if you have?
If problem there also excists, then return box.
