This issue seems to occur randomly. I notice it happening with both advanced & current recordings. I can set record for a programme that epg shows is on for 15 mins but then the recording timer will default to 1 hour once it starts. I do remember some time ago setting a manual recording for a duration of 1 hour for a channel that had no epg info. But once I started recording on other channels with epg it recorded like normal. To overcome this problem I've tried a few things - factory reset, recording to sd card, recording to USB, using different file system ntfs or fat. Can anyone suggest anything else?
