Recording 2 consecutive programs same channel does not work
  • Every time I set 2 recordings one after another on the same channel the 1st recording works but the 2nd recording does not happen.
    Example: Set a recording to start at 10am to 11am on channel A and again a recording at 11am to 12pm on channel A
    The first recording 10amto11am works but the next recording fails!
    Also it would be nice to be able to set a recurring recording: Every week at same time same channel!!??
  • Thanks for the report. Will ask the engineers to check on it.
    Recurring/Manually set recordings will be available in a future release of MYTVOnline
    Does it work if you say record from 10-11 and then 1101-12
