Z-Nano not booting show loading SCREEN
  • Z-nano starting, but freeze on Loading screen.
    spinning wheel, nothing goes further and I will wait an hour...
    What are the possible solutions?
    JTAG
    USB BOOT
    LAN BOOT
    Is tools for recovery?
    Send to RMA ? ONLY
    We already have four units of 200pcs
    waiting for solution ASAP
    best regards Vaidas
  • Newly unboxed unit or unit that has been used for awhile?
    Try to reboot without a network connection to the box.
    If that doesn't work, use the USB factory reset tool - attached.
    Unzip to USB root.
    STB POWER OFF
    Insert USB
    STB POWER ON while repeatedly pressing the CH UP button on the RCU (press repeatedly, don't just hold it down)
    You should see the Android Robot update animation on screen
    At this time you can stop pressing the CH UP and wait for the reset procedure to complete.
  • thanks for you poste:thumbs_up:
  • Hi
    Can anyone help, I did everything as they did:
    1-Unzip to USB root.
    2-STB POWER OFF
    3-Insert USB
    4-STB POWER ON while repeatedly pressing the CH UP button on the RCU
    on screen appears Robot update animation, but then appears image with ERROR!
    SF: V2.8.49
