I have a problem with a z7+ formulation.
The following message appears when the decoder starts (
Launching IPTV keeps stopping)
Can you help me
Can you help me
Problem solved with manual reset
Updated my box yesterday and today when I went to turn on my box I have the exact same issue except even after a manual reset the error keeps coming up.
I'm stuck on the error no matter what I do!
Please help
I put the USB flash drive on the right port of the box and then restart the box and press the ch up key several times. And now he's going to ask again in normal mode.
Otherwise you should check with a site administrator.
Sorry for my English, but I'm Belgian.
My box starts but it turns off automatically. How do I solve this problem?
I've changed the stanby settings so that the box ends when I press the button. but now I can not roll back the settings because the box shuts off and lets nothing.
Please help
Ok you mean with update the latest one, firmware 1.2.42 and Mytvonline 1.9.52.
Does this happens also if you plug out your usb/sd card/hdd and restart the box? Please go to system and try again with factory reset/software reset.
Sam, you can help me.
Turning off automatically is very strange, never saw this on my boxes.
If the box not boot up, try factory reset with this instruction and file -> Z Series Instructions / Z Serie Anleitungen
Then update your box first until you have the latest firmware and MOL version.
Thanks a lot Sam.
Update:
I was able to use the .ird file on a USB stick and did a factory reset. After the factory reset it works fine.
Hello
My z7x crashed when I would update it to the latest version.
What appears on the tv is the loggon Z7 + and a green lamp that blinks on the box.
Is it possible to download a new version of the new file on a USB memory and update the box to work again?
if that's possible where do I find that file?
/ Mikael Rydhage
Like already in PM answered.
QuoteHello,
Please download this file and instruction ->
AdministratorApril 28, 2018 at 10:36 PM Do the Factory reset and try again to install newest update.
Regards
Sam
