Z8 is great. On latest updates. Connected to my provider via MAC adddress and their server URL. Three issues with EPG:
1. I can’t select and go to channels with it. Just doesn’t work. I hit the yellow button to go to current program and it still won’t select. Try different programs at different times and that doesn’t work.
2. It is off by about 5 hours. I tried timeshift to On but doesn’t work. May be related to above. It shows the right time but the actual content at 7pm can only be found when I scroll over to 12am.
3. Design issue. The background colour just doesn’t match the rest of the menus. A tranluscent simple grey will match. But, all the other menus are flat grey and translucent and then suddenly the EPG has this wonky colour so it looks like it’s from a different UI. I’m coming from the T1+ which had a uniform and clean menu system so I know the designers would be aware of this.
