Cant update the z7+ firmware, the market also not working. Formuler server issues ?
- Miscellaneous
- Z7+
Fabsimon -
February 27, 2019 at 9:25 PM -
Yes, it seems the server is now in maintenance mode or offline at moment. Box needed also to long at start for check and synchronise. Try tomorrow again.
Update servers maintenance confirmed now, they work on the servers.
Any idea when it will be up again as I have a box that needs settings up
Start the box and leave for ca.10 min, home menu will be shown and you can use your IPTV gain for watching.
Maintenance affects only the update and market. In this case, check again in few hours and do then your needed updates.
That’s my problem as I deleted mytv online as it got stuck on the load up screen.
This is a new box and my 1st formula one. Have to say I’m not impressed so far.
Update: Should work now fine again.
Okay I will try again
No market is not loading up
Also when loading software update it still hangs on notice and loading.....
then finale goes into software update but stays saying current version which mine is v1.2.60
Seems to be working now
With market, try little bit later, maybe they are not finished with all files. Your Firmware is 1.2.60, this will not change because it is latest one and like you already told you deinstalled MYTVonline and need only this to install again.
