XtreamEditor Multilist and Epg
  • Hello,
    I added two Providers as an Api Line in Xtream Editor and assigned the Epg. Then I created a Multilist in Xtream Editr with both Lines. Now when I put the m3u download link from Xtream Editor in MOL2 everything works well and both lists show up together as one. But i cant figure out how to get Epg work. Even if i put the download link from the EPG (from Xtream Editor) in MOL2, it doesn't work. If I put the .xml file on a Usb, it doesn't work. What did i do wrong?
  • I got it working somehow. But i want to adress a problem with MOL2. When i put the EPG Link from XE the Epg shows up in Mol2 but it crashes without any message a few minutes later.
    Edit: Also MOL1 on the z7 crashes with the EPG Url. Mol1,2 can't handle larger Epg files?
