Which Bluetooth Dongle? Urgent.
  • I have the crap US version without Bluetooth. I have read conflicting threada about which BT dongle would work with this model.
    So what is it?
    The RTL8723BU dual dongle
    Or
    Csr8510 bluetoorh dongle
  • You will need to purchase a USB WiFi+BT dongle that contains the RTL8723BU chipset.
    Not all USB adapters containing the RTL8723BU are supported however.
    You can try to search the forums for feedback on which adapters have been tested as working.
    Closed the thread.
