Just bought the Alpha and I'm wondering if it's possible to controll the sound on my Sonos beam with the formuler remote?
Is there any way to program this or is it just the two buttons on the top thats programable?
Only the two buttons can be programmed.
Ok, thanks.
Is there any other way to solve this?
As it is for now I have an extra remote just to change the volume since the volume on the box doesn't give any adjustment in the volume. Either it is off or the same volume the whole time no matter how many clicks to the right I go.
Logitech Harmony universal remote would be very good solution to control all devices with one remote.
I have also Sonos
And with the remote from my Z8 , the sound from my soundbar etc etc , can be adjust.
Or you mean something else ?
I have also Sonos
Sorry for late answer.
Is it really the volume on the sonos ju adjust?
I just can adjust the volume panel on the Formuler box since the volume buttons on the remote can't be programmed.
I know that the volume increase at the sonos but the adjustment is done in the formuler,right?
Or how are you doing this otherwise?
