I'm a newbie and have been trying for a good week to get the MVTVOnline 2 App to properly display the EPG. The EPG is completely off and shows information for shows that are either in the future (by at least an hour) OR shows information for shows that aren't even playing at all on that channel any time in the past or future.
I have tried to follow the guide :
- Mytvonline 2 > Connections > Current portal - Edit
- Scroll down to the bottom and change EPG mode to UTC or Normal
- Scroll down to the bottom and set EPG offset if necessary - Press UPDATE
- Check if the EPG data line-up is correct
However, these settings don't exist anywhere in the app. There is no option for any of these things mentioned in your help file other than a toggle to turn timeshift on or off. (Doing so makes no difference in the EPG being incorrect)
Thanks!
