Hi everybody,
I tried to use VPN cyberghost, but it never worked.
Could you confir me, that this vpn don't work in that box?
Hi everybody,
If you already use that service ,Put the VPN on router then everything is on Vpn
Nord VPN works fine here on Z8, cyberghost should also work. Someone else here using cyberghost?
Nord works good here toooo
According to some people nordvpn is ok
But I didn't find anyone who use cyberghost, and in my z8, I got black screen and no connection anymore when cyberghost is active.
I have been using Nord for years on apps and openvpn , if you do have a problem they help quickly.
I have trialed others but as yet nothing has convinced me to change.
And this happens on Z8? We have reports that such things happen on Z Prime <> Z7+ (hotfix will come next week) but not on Z8 or Z Alpha.
Sam, I confirm 👍 on z8
Or if anyone has a solution
He is welcome
Then is this some issue with cyberghost. Did you try to deinstall current version of cyberghost and install new one?
I just had a thought it isn't your provider that does not like VPN being used. I had a trial once and he blocked me for using VPN
I don't think so because I use it for my smartphone and pc
Yes but it seems not fit
