Wifi connection - other network
  • I have a Formuler Zx 5G.
    I want to connect via wifi.
    However, the wifi (vacation hotel) is on an “Other” network. Meaning you have to set it up manually. It will not appear in the list of wifi spots when you look to connect.
    the only problem is that I can’t see to do this...to set it up manually.
    Alternative is to connect to my phone using a hotspot and then connecting through the hotel’s Wifi and logging in through Firefox like a thread here has suggested.
  • Home > settings > Android settings > WiFi menu
    You should be able to manually add the SSID in the above menu
