Hi guys,
Not sure wether this can be fixed by the z8 box or not .
On my epg, I get the normal Tv channel list, bbc 1 bbc 2 itv 1 etc....
But they are I guess the London region, how do I change this to get my Tyne tees region ?
Hi guys,
Think it will be provider. Some will also have a regional group
If your provider stream such channels then you should see them, if not then no such streams included from your provider. With dvbt2 antenna and dvbt2 usb stick you can bypass this and have regional tv.
Cheers guys ![]()
My provider is abroad based so your probably right about not having Uk regional variations .
Thanks again .
I do have the usb-aerial stick Sam,
if I connect my roof top aerial to this, can I search for terrestrial channels through the z8 and where do I go On the z8 to select this aerial Connection.
Thanks 👍
I guess ideally I’d get a better quality signal if I used my now unused Sky dish , but I have 2 lines coming in the house from this, can I somehow use these or one of these lines to connect to the usb/aerial stick ?
the usb/aerial stick does have the older type female connector though , wonder if I can get a sat screw type to terrestrial type adapter or something ?
You can get F type to RF male and female .
If its a Terrestrial your dish wont be any use anyway if its sky Q type lnb its wideband
It’s an older sky dish setup, way before sky q .
Cheers, I’ll look for one of them connectors
Insert USB DVT2 stick first, then -> MOL2 menu -> Connections-> Terrestrial.
