Hi people when i deploy de mol config , after i cant delete the custom config in MOL2 (formuler Z ALPHA)
help please
help please
Hi I'm not 100% what you mean, But why don't you EDIT it instead of delete
when you push a custom config to a formuler box with mol2 you cant delete it after...
i tried factory reset, clear cache,.... nothing helps.... also backup from 1 other box and recover it to the box in question but nothing.... the configuration version remains.... also the custom config i pushed..
how factory reset 100% ???
Are you the owner of the config?
Yes i am
Read the manual for the Remote Configuration tools - page 14
Thanks for the help, its working !
Some things that is not working with the config:
- Set as Startup App is not working
- Homepage background (1920 x 1080) didnt change also...
- MOL2 logo also not changed
thats all... all the rest is working!
can you help me for this?
thanks
