Can you activate cursor, i don't see if anywhere. Most iptv box has this feature.
Z8 Pro remote does it have mouse feature.
md66 -
November 13, 2020 at 1:48 PM -
On the GTV-BT1 Bluetooth remote you have to assign a key with app ( Source button long press was supposed to work in ir mode )
https://drive.google.com/file/d/1Qk_jTV…n7P2HeVdPP/view
When I win mine I'll have a play LOL
I have the remote that came with Z8 pro.
that is what link is for
Hold the Button with 4 dots longer, mouse cursor should appear.
If not, go to Market and install the latest version 1.0.1 from Formuler Remote app, choose your IR Remote and go to Setup Hotkey, now you will be able to set mouse cursor.
That worked. Thanks
and how to make keyboard appear?
Thats what I said in ( ) LOL
Is the 4 dots Source button?? No It not I am daft
