It seems the FPS dropping ob FullHD channels causing unfluid image on fast image movement. The problem is not present on my Z+ Neo but only on the new GTV.
Is this problem known? I installed all updates available
I'm having the same problem
me 2 on some
Is AFR in use? Try with enabled Auto Frame Rate (MOL2 Menu).
No AFR is not in use.
Still have same problem
AFR On/Off still the same problem
Same problem, FHD channels not displaying fluids
AFR not the source it seems like framerate drops to 15 frames or so
Just got a new GTV and the same thing was happening me. I found a other thread on here that recommended setting the resolution to 1080p at 50hz which has made a big difference. Hoping it’s some kind of software thing that can be rectified with an update
Yes the only solution but makes a 4K box pretty useless
I turn off Auto Frame Rates in Myonlinetv2 setting and no more black screen.
if i do this i have lag problem
This Auto Frame Rate seems to work fine on Z8 and I haven't tested it on the GTV.
GTV is buggy and needs to get fixes out soon.
