  • Hi,
    I'm having trouble with the Replay again. I use the formulate Z8 pro and MOL2.
    On a lot of replays there is a bug that takes you to the end of the Replay.Example: a top chef show lasting 2 hours. You want to move forward so as not to have any advertising and all of a sudden the video ends up at the end. Even if you go back the problem will be still there. It is therefore impossible to watch multiple Replay.There is also the same bug when the Replay is cut into two different parts. When we arrive on the second part, the bug is present we find ourselves at the end of the video Without being able to do anything.
    For information, I have this bug on several formuler. (4 Z8 et 2 Z8 Pro)
    Thx in advance for your help
