I am using Tivimate. If I use the hardware decoding as opposed to software decoding (which is too slow to be usable), the box will freeze after several minutes (maximum) while watching tv. This seems to only occur if the box is using WiFi at the time. If I disable wifi and connect via the wired interface, it does not seem to freeze. The box will usually reboot after a couple minutes, presumably when a watchdog timer times out. Until that happens, it is completely unresponsive as far as I can tell, and the display is "frozen".
I wish to use the box in a room where I cannot run an ethernet cable. Anyone should be able to reproduce this with the latest version of tivimate. I have had hardware codec/freezing issues with other apps as well, but this is the one I really care about.
Also, Is there a url to open a trouble ticket? I can't seem to find it.
Thank you for your help.
