Hi there,
I've bought a GTV and already had a z8. Is there a way to use the remote from the z8 on the GTV?
Sincerely
Hi there,
Sincerely
Which remote do you have, If its original Z8 I think they are different and won't work
It's the one on the right. Also in the manual of the bt remote it states on the colored buttons hotkeys, follow the on screen instructions. Can I also program them? It was possible on the z8 remote
Cant use that Z8 remote with GTV.
The BT remote is a great remote. Yes pair with box Bluetooth then open formuler remote app.
Aaah that's too bad. Well I did that and I can only program the 3 buttons on the bottom?
It will work with limited functions...limited as in the basics...volume, Channel up down, power standby, left right, back, number pad, epg button...No back & tab vod resolution vformat buttons...maybe record.
Anyway
To do what you're asking - On the Main screen - you need to go to Apps and open Formuler remote app
I select "GTV-IR1" and select "Setup Hotkeys" and set your shortcuts
MY kids use the Z8 remotes on the GTV's (They often break them & of the 3 the Z8 remote is inexpensive to replace)
I use the GTV remote on the CC and the CC & PRo remotes as backup to the GTV
It will work.
Enjoy
Cheers I was understanding old ones wouldn't work past Z8 . read it somewhere. every day's a school day.
I shouldn't be in GTV section anyway ![]()
