I am having an issue with my GTV using MYTVonline2.
When i power on from standby the portal is not able to stream any channel that i try. Just black screen. When i reconnect to the portal all is fine again. Until when i try again from standby mode, power on, and same behaviour. Almost always i need to reconnect the portal or restart the box. Going into VOD/series also display an error on everything i try - until i reconnect, then all os fine for a while.
I saw other post about 10-15 delay to show picture on some GTV, however tried to wait many times, with no luck. Only reconnect will solve the problem for a while.
Using m3u works just fine on all my other devies using the same user/connection and also trying m3u also works just fine.
