hello. since a couple of day. maybe since the last update I can't sort anymore in tv series. VOD movies works. But if I sort by maybe title or rating it doesn't take effect. Any idea ? Am I the only one with this problem ? THX4NFO
not possible to sort anymore in tv series
Please give us more infos.
1. Connection/Protocol in use with Provider (Stalker, XC Api or M3U).
2. Only TV Series affected?
Stalker Portal Login via Z8 ID. And yes, just in TV Series affected. Thanks for your help.
Tested with Stalker and last update, works fine on my side. Delete cache in your MOL2 app, maybe this can help.
Send you video url from test in PM.
Hello SAM. Please check your PM. THX
Answered.
Hello SAM. Please check your PM again. THX
Hello SAM . Please check your PM again. THX
