Remote
  • You can only turn off one programmed device if using the BT-IR1 or GTV IR1 remote such as if it’s paired with your tv.
    Not like a harmony remote where you can program multiple devices.
    I trust that’s what you’re referring to?
    If think also if using the older Z8 remote or the IR-1 you can have one device (aside from formuler box) paired with various actions aswell through learning mode?
    There maybe a workaround in that you can purchase cheaply an IR extender with 2-4 emitters attached to it but only then will all connected devices power on and off at the same time anyway
    Edited once, last by adrilang (June 22, 2021 at 8:03 AM).
