Increased Mbps when using VPN?
  • I am connected via an ethernet static IP address on my GTV and have fiber optic, when using a Surfshark Denmark VPN I am getting download and uploads speeds of 89Mbps/16Mbps, while without a VPN I am getting 45Mbps/8Mbps.
    I can't see how the higher speeds are correct unless my internet provider is capping my speed and the VPN avoids the cap, I am using a fiber optic speed test App downloaded from the Google App store, and have tested a few times with and without the VPN connection with the same results, just tried again on a Polish VPN using Wifi again with a static IP address and this time getting 88.18Mbps/14.57Mbps with VPN on and without VPN 46.06Mbps/7.99Mbps so it is not the VPN.
    I thought that a VPN killed the speed so can anyone confirm or explain what is going on, I would have provided a screenshot of my results but I don't have File Commander on GTV and can't recall how to connect my GTV to my laptop.
  • Are you using Shadowsocks protocol in Surfhsark? If yes, this seems common issue. Try to change protocol and try again. Also this Fiber optic speed test app is not best, I saw it. You would be better with sideloading Speedtest app.
    Thanks M8, will have a look when I am not using the GTV to watch footie and get back to you:thumbs_up:
  • Hi GR, My protocol was on automatic so I changed it to Wireguard and tested again and was still getting a higher Mbps when using a VPN, so I have sideloaded Ookla Speedtest and I am getting more or less the same Mbps with or without a VPN.
    So I don't think it is necessarily Surfshark but the Fiber Test App that is duff and now uninstalled.
    Thanks again,
    James.
