On the Z10 Pro Max, after having installed and enabled Leankey Keayboard Pro which is for many users much better, with several languages like French with all the accents on the e, i, o etc, and much bigger than the provided Gboard, and was perfectly working in audio on Z8 and Z8 Pro, and after authorizing use of the microphone, it looks like it is listening with the red point and the "beep" (so as it was on the Z8/pro)...but not writing any word in the search bar !
Voice search impossible with another virtual keyboard (Leankey Keyboard) than the default provided gboard on Z10 Pro Max
- MYTVOnline2
- Z10 Pro Max
cedel -
December 5, 2021 at 9:20 PM -
same issue on the Z10 Pro. I tried several versions of Leankey kb (the last : 6.1.19; also 6.1.13 and 6.0.5). I also tried to disable gboard, micro access from gboard, then but it back on...I also have problems to search vocally in BT with the Gboard...it works rarely and never with leankey keyboard
Correction, the voice search with Leankeay Keyboard Pro finally "works" but veeery slowly, the results appear ONLY after 30 or 31 seconds (! which is an eternity if you compare with the 1 second or almost instant result on Z8 and Z8 Pro) and here 30 seconds with a message "recognize other error 2" at the bottom of the screen, I have tested the 2 kinds of connections MAC adress or XC codes...same problem !
Which Firmware you use on BT1 and version of Formuler Remote app?
with the provided Gboard that I don't like, the voice search is instant but it takes often only 1 out of 2 words...try "Alain Delon" in French, it takes only "Alain"
The last : AppV1.2.1 . the firmware is 0.5.30 and when I try to click on Setup Volume Control, its written: "This feature is supported from remote v0.5.35 or higher". I heard there is a beta vesion of the remote app for the GTV but I don't know if it will be the same and valid for the Z10 Pro série, and solve this problem of 30 seconds to recognize words instead of instantly and with this error message " recognizer other error 2" ?
hi Sam
when will the new remote firmware v 0.5.38 be available again ? On Z10 Pro and Z10 Pro max I have only the 0.5.30 and I guess that my problem of vocal recognition with Leankey Keyboard Pro (that you can put much bigger than Gboard) problem that it does not work almost instantly like on Z8/pro but lasts an infinity of 31 seconds and produce an error comes from the version of firmware.
Not sure though because I can well use for vocal recognition any chinese cheap google voice remote with usb dongle without problem with Leankeay Kb on Z8 pro....but the same error on Z10 Pro and Z10 Pro Max...so, would the Formuler Remote App have something to see with voice recognition, also for a "foreign" basic chinese voice RCU with USB dongle?
Please don't post the same content repetitively on different articles. It's against the forum rule and could limit your access if repeated.
With your questions, I'll PM you.
I have again the voice problem on all the BT Z10 serie since more or less 2 months, even the new beta of 22/09/22 did not solve the problem: the provided virtual Gboard on Z10 comes without any micro button, making it impossible for a voice search in MOL2.
Something strange is that older devices (my Z10 is from 22 August2022) updated have well the microphone on the GBoard.
Go to Google Play Store and search Gboard.
Click uninstall update and update the app to the latest again.
hello: it is impossible to uninstall, even in Play Store -"manage applications", the button "Uninstall" (present with some other users of Z10 Pro Max -here, has disappeared, it is a the same for 5 other Z10 bought at the same time on August 22 in Belgium from Seeandsound, the Belgian-France official importer)
After the new official release (that seems not to change from the beta: no download, no sign that there was a new realease on this 29th September): still the same problem :
even with Leankeay Keayboard activated,Micro authorized, GTV-BT1 of course paired in BT, NO VOICE SEARCH IS POSSIBLE in MOL2 ON 5 pieces of Z10 bought on August 22nd in Belgium by Seeandsound the Belgian-French importer..Seeandsound have also signaled the same problem to Formuler they told me..
Waiting for a working software or Formuler Remote update !
A friend has exactly the same issue with not voice search possible in MOL2 (but in Youtube well possible) after a hard reset on a Z10 PRO device bought in January or February 2022
Please proceed with Formuler Helpdesk
