mini keyboard instructions
  • I recently bought Z10 Pro Max from Amazon shipped and sold by Formuler. It comes with a mini keyboard by Formuler. There was no instruction about how to use. The brand says Palm Remo P-03 and tried looking up the internet to see if I can find the manual but no luck. Can you someone point me to where I can find the instructions.
  • It comes with a mini keyboard by Formuler
    Formuler doesn`t sale mini keyboards, this must be extra attached from seller. Amazon link?
  • I guess i would be one of the first Admin`s informed from Formuler, if such mini keyboard would come from Formuler and goes into sale.
    Such Accessories or extra devices would also appear here on forum (even before sale starts) and that is not the case :winking_face:
    Looks like NA distributor made some extra package with Formuler silicon cover and other two items like hub and mini keyboard from other manufacturer.
    To be 100% sure i will ask Formuler directly and let you know.
  • Already got answer, it is extra attached item (hub and keyboard) from NA distributor and not from Formuler. Please ask him for kb instruction.
  • Thanks Sam for your quick response.
    Even though the same product was listed by other people with Amazon return policy, this one is listed as third party seller which means returns is not that easy. In spite of that I went with this seller because I thought I am buying directly from Formuler which is very misleading. If customers have issue with returns or other issues, they will have very negative view of Formuler not the NA distributor. I am sure Formuler as a company doesn't want to own all of a distributor issues just because they are misleading customers into believing that they are getting the product directly from Formuler.
  • This question is for Sam.
    Most sellers on Amazon include freebies and consistently priced at $169 but I found one seller not listed on Amazon selling for $129 without any freebies(didn't want to take the risk, since no guarantee the product will be genuine). Wouldn't Formuler like just their products to be sold at a lower price to be competitive rather than sell at a jacked up price with all the freebies you may never use like extra remote, car mount. I for sure settled on MAG524w3 initially due to the price but had to go for Formuler because MAG524w3 absolutely had no support. I am sure lot more like me who might have given up on Formuler because of the price difference.
  • I finally figured out there is usb dongle inside the battery compartment and you plug it in and works right away. If this information was given to me by the seller, it would have saved lot of my time trying to figure it out
    The dongle is always stored near battery on such devices!
    Ok, means no distributor, it`s 3th part seller. You should know that everyone can be reseller if he show right documents and buy more than 20 pcs.
    What seller or reseller do, what they include in the package and if they sale kits with many other accessories, is responsibility from that seller and not Formuler. If they sale something that is not Formuler product -> as Formuler product, then it is bad and should be reported, but Formuler as manufacturer can not control each seller. Should be reported on Amazon about the fake mini keyboard product.
    Formuler is only responsible for they own Boxes and Accessories + RCU`s that goes in sale with Formuler name + Formuler do not sale directly. It goes from Formuler to distributor and sellers buy from distributor!
    What Formuler sales under Formuler brand name, can be read from each Customer on this Formuler main page -> https://www.formuler.tv/
    It is also responsibility from each Customer to do some research, ask in such forum, check the manufacturer site and compare the infos before he buy same product. Blind buying was never good.
    Such kits can be only found in NA area, in other areas it is almost not existent and only the boxes are in sale. Accessories can be buy separately. Only in few cases are some extra kits with + BT1 RCU remote visible, but in most cases only the standard products.
    If you have such worry about what is real and what not, then buy directly and only the box for cheaper price directly from distributor in your area.
    That is all i can say and i hope i explained everything :winking_face:
