Ambient light Application for Android
  • Hi folks!
    I just installed a led strip and use Ambient light Application for Android to control it. It works fine with YouTube app and within MTVO2 un the menus but not when playing a movie or a TV program. Does someone has resolved this issue? :thinking_face: Thx!
    Ps: it works fine with IPTV Smarters so I use this one to watch movies 😅
    Edited once, last by Pi0091 (July 26, 2022 at 2:47 PM).
  • MOL2 on Z8 doesn't use the standard system video player so the ambient light app cannot read the color values.
    The workaround is to use an external VOD player app like VLC or MX player inside MOL2.
    MOL2 > Main Menu > Settings > Player Options > External VOD player
    This however will only solve the issue when you are playing VOD and not Live TV.
    The other workaround is to purchase a Z10-series device or GTV as these two devices use the standard video player.
  • Thx!
    I tried with VLC and MX but the video doesn’t show up in these apps (I only get the sound). Is there a setting to turn on/off?
    Edit: I got the video with MX but Led are not working
    Edit 2: got it to work with Nova Player. The only one doing it great and free 🎉🎉
    Edited 2 times, last by Pi0091 (July 27, 2022 at 8:23 AM).
  • Thx!
    Glad to hear you got it working.
    Can you post a link to the ambient light bar you are using?
  • € 15,79 Réduction de 20% | Bande lumineuse LED rgb 5050, 1- 5M, rétro-éclairage d'ambiance, ambiance Festive, luminaire décoratif d'intérieur, idéal pour une fête, un jeu ou des vacances
    € 15,79 Réduction de 20% | Bande lumineuse LED rgb 5050, 1- 5M, rétro-éclairage d'ambiance, ambiance Festive, luminaire décoratif d'intérieur, idéal pour une…
    a.aliexpress.com
    Yesterday the app (Ambient Light) crashed several Times while watching a movie with IPtv Smarters. I’ll try with Nova today to see if I got the same issue.
