Please tell me there is a possibility to disable PiP-function?! Or if not disable, then at least change it from the OK-button to something else? It's really annoying that if you hold the OK button just a few seconds, it activates PiP, and it is troublesome for an elderly person with no tech abilities to get out of it.
Is there a way to disable/change the PiP-function?
