Hi, is it possible to change the TV/STB button so that it works in reverse?
That is, I need to hold it down for 3 seconds to turn off the TV and only press it once to switch to IR mode. If this is not possible, would you consider adding this feature in the next update? It takes a long time to switch sources on the TV when I have to hold the button down for 3 seconds to switch and then 3 seconds again to go back to controlling the box.
