2 weeks ago I booted my Z11 Pro Max, only to see a message: System shutdown initiated. I could cancel the automatic shutdown by pressing Back or OK on the remote. I tried both several times, but it always ended in a shutdown.
I then connected a USB keyboard and I was able to prevent the automatic shutdown. However the remote still wasn't working. I was (and am) still able to control my Sonos soundbar and Sony (Android) TV with the GTV-IR1 remote.
I have tried the following:
- Replaced the batteries with brand new ones > no result.
- Disconnected the IR extender > no result.
- Tried to use the remote at different distances > no result.
- Tried relocating the Z11 to another floor of the house > no result.
- Tried a factory reset (Settings > Device Preferences > Factory reset) > no result.
- Tried a factory reset through the recovery menu (Wipe data/factory reset) > no result.
- Contacted the supplier who sent me a new replacement GTV-IR1 remote > no result.
I'm out of options as far as I know. Does anyone have another tip/option that I could try?
Specs:
System: Formuler Z11 Pro MAX
Current Firmware Version: v11.2.6
Current IPTV Version: v11.2.15
Current Service Version: v11.2.1
Current Tuner Version: v11.2.2
Current Storage Version: v10.10.31
Formuler Remote App Version: v1.3.0
