Firmware update S-Series / Firmware Aktualisierung S-Serie
  • Applicable Models: S Turbo and S Mini
    _____________________________________________________________________________________________
    Updates 25.06.2019
    • Firmware Version : 1.6.54
    • MYTVOnline Version : 1.09.79
    Update procedure:
    Download the latest S-series update from the Software Download menu.
    Classic: Menu -> Manager -> Software Download and start with download. Please let the Box do all steps automatically including reboot.
    Modern: Menu -> DVB - Software Download and start with download. Please let the Box do all steps automatically including reboot.
    Important: Software cannot be rolled back after installation.
    The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much longer then usual, please be patient and let the box finish the install.
    Release Notes:
    Firmware S-Series Version 1.6.54
    • ADD : C-BAND LNB 5150/5750 for single solution LNB's
    • ADD : Multi satellite scan feature
    • ADD : Weather widget revised
    • ADD : Weather search by city names
    • ADD : Delete, rename option in File Manager
    • ADD : While scanning satellite, it will show the name of satellite
    • ADD : Bluetooth and power mode shortcuts added to the main menu
    • IMP : File playlist browse, delete options
    • FIX : Bluetooth connectivity issues
    • FIX : Pause video in timeshift shows Service Error
    • FIX : TTX subtitle of IP channels not working
    • FIX : Device crashes when T2 signal is low
    • FIX : Force closing of certain APK
    • Various bug fixes and performance improvements
    MYTVOnline version updated to latest version 1.9.79
    • IMP : Increased refresh rate of detailed stream info
    • FIX : Radio channel streaming issue on certain portals
    • FIX : Episode playback issue on certain portals
    • FIX : Crashing issue when switching portals
    • FIX : Favorite list changes if m3u list is updated
    • FIX : Page scrolling issue in TV Series section
    • FIX : xmltv EPG parsing issue
    • FIX : Cell overlap issue in Program Guide
    • FIX : HLS VOD playback issue
    • FIX : Group Channel Numbering preference changes after applying Installer Mode config
    • FIX : Recording stops if stream buffers
    • FIX : m3u channel parsing issue
    • FIX : TV Series playback/seek issue
    • FIX : Favorite channels disappear when using Xtream Codes API
    • FIX : Timeshift file is created on USB even if Timeshift is set to OFF
    • FIX : HLS streams don't auto-recover after network instability
    • FIX : No sound issue when returns to SAT channel from mytvonline by IP/SAT button on RCU
    • FIX : Image retention issue after closing mytvonline and returning to SAT channel
    Formuler.tv
    Updates 26.11.2018
    • Firmware Version : 1.6.26
    • MYTVOnline Version : 1.09.58
    Update procedure:
    Important: If you forget to do factory reset before, please do it now.
    Release Notes:
    Firmware S-Series Version 1.6.26
    • Improved display of extended xmltv EPG event data
    • Patched incorrect character encoding issue in EPG event data
    • Added 3 more user-definable xmltv EPG slots. (4 total)
    • Added Clear EPG database feature. Grid EPG > Green hotkey
    • FIX: Stuck in Standby issue
    • FIX: Weekly timer issue
    • FIX: HDR mode issue when HDMI auto adaptation is enabled
    • Improved Turkish translation
    • Added compatibility for startonboot, playstore, settingslock, appslock from Installer Mode settings
    • Added Startup app feature
    • FIX: mkv playback issue from Playlist screen
    • FIX: Displayed EPG Language not matching system language when multiple EPG languages are available
    MYTVOnline version updated to latest version 1.9.58
    • M3U supported
    • Teletext Subtitles supported
    • Manual EPG time offset. Access from the Settings menu
    • Xtream-Codes API portals > TV Series section supported
    • VOD > Continuous play option added. Press the Green hotkey to toggle
    • Automatically hide empty groups/categories
    • Added stream codec details. View from the detailed information popup window
    • TV Series Shortcut. Press and hold the VOD button on the remote
    • Remember last selected subtitle preference per channel
    • Improved channel icon caching
    • Improved EPG download performance
    • Inactivity timer improvements
    • FIX: Black subtitle font when only 1 subtitle track is available
    • FIX: RCU VOD hotkey while in Classic Channel list
    • General performance enhancements, UI improvements, and bug fixes
    Formuler.tv
    Updates 26.06.2018
    • Firmware S-Series Version 1.6.11
    Update procedure:
    Important: If you forget to do factory reset before, please do it now to let all changes work correctly.
    Release Notes:
    • Overall EPG performance improvements
    • EPG data saved locally
    • XMLTV EPG supported
    • OPEN EPG format supported
    • Added Fast Scanning for some providers
    • Fixed channel editor numeric keys bug
    • Fixed segment duration issue for certain streaming IP contents
    • Channel zapping speed improved
    • Fixed T2-MI scanning issue
    • Fixed Unicable - manual SCIF frequency saving issue
    • Added separate Timeshift/Recording device option
    • Improved launcher UI performance
    • Fixed certain app compatibility issues
    • Android Security Patch Level Update : April 1, 2018
    • General fixes and stability improvements
    MYTVOnline updated to latest version 1.9.36.
    Here are only few important changes since the last version.
    • XC Portal > Fixed VOD loading issue
    • XC Portal > Fixed Live TV and loading issues
    • XC Portal > Added xmltv EPG feature
    • VOD > Improved appearance of subtitles. White font with black shadow.
    • Fixed DVB subtitle display issue
    • Fixed 'Stuck in Standby Mode' issue
    • Fixed MYTVOnline startup delay issue
    • TV Series section added.
    • EPG downloading speed improved.
    • Black screen issue patched.
    • Fixed VOD playback issues with certain servers.
    • PVR performance improved.
    • Long recording file playback issues fixed.
    • Fixed playback of multi-part recorded files larger than 4GB
    • Username/Password login issue fixed.
    • Empty Channel List - Server login issue fixed.
    • Added xtreamcodes API.
    • Mapped keyboard F7 key to EPG.
    • Fixed UDP stream recording issue.
    • Fixed old HLS Startmode issue.
    • Event reminders patched.
    • Various portal issues patched.
    • General bug fixes and performance enhancements
    Formuler.tv
    Updates 06.03.2018
    • Firmware S-Series Version 1.6.0
    Update procedure:
    Release Notes:
    Firmware S-Series Version 1.6.0 (r13606)
    • Added channel search to Simple channel list
    • Press the Yellow key when the Simple channel list is on-screen
    • Added hidden apps section
    • Added Simple channel List OSD Transparency control
    • DVB [lexicon]Settings[/lexicon] > OSD [lexicon]Settings[/lexicon] > Channel List Transparency
    • Patched HDR contrast issue
    • Improved IP Channel playback when network is unstable
    • Airsync Remote color hotkey issue patched
    • Fixed manual Ethernet [lexicon]settings[/lexicon] issue
    • Fixed IP channel playback after reboot when using WiFi
    • PQ [lexicon]settings[/lexicon] can now be changed in HDR mode
    • General UIUX improvements
    Very Important - new recovery mode!
    New factory reset recovery mode. For use when Android is not loading properly.
    • AC power OFF > AC power ON
    • Repeatedly press the Red key until the front LED flashes alternating RED/GREEN
    • Press 1 on the RCU to factory reset the device
    Extended Info.
    Formuler still working on the EPG and Fast Scanning improvements. Plan to have these available in the next release.
    Formuler.tv
    Updates 19.12.2017
    • Firmware S-Series Version 1.5.2
    Update procedure:
    Classic : Menu -> Manager -> Software Download and start with download. Please let the Box do all steps automatically including reboot.
    Important: If you forget to do factory reset after 1.5.0 Update, please do it now.
    Release Notes:
    • Added ability to start/stop Samba Share Daemon Access from Android [lexicon]Settings[/lexicon]
    • Access from Android [lexicon]Settings[/lexicon] (User -> SAMBA Service)
    • Improved Network [lexicon]Settings[/lexicon] UI/UX
    • Fixed WiFi disconnection issue after configuring from Android [lexicon]Settings[/lexicon] WiFi menu.
    • Repeat keystroke when holding Channel UP/DOWN on RCU issue fixed.
    • Fixed random no-boot issue.
    • New Launcher now responds to mouse cursor commands and compatible with Air Sync Remote app.
    • YouTube updated with mouse cursor fix.
    • Download the new version from the market.
    • Improved on-screen keyboard readability
    • Favorite apps now synced between Classic and Modern Launchers
    Formuler.tv
    Updates 06.12.2017
    • Firmware S-Series Version 1.5.0
    • MYTVOnline Version 1.8.8
    Update procedure:
    Menu -> Manager -> Software Download and start with download. Please let the Box do all steps automatically including reboot. After Install we recommend factory reset at this state.
    Release Notes:
    • NEW Modern Launcher (Main Menu) option. (AndroidTV Leanback-style)
    • Access from [lexicon]Settings[/lexicon] > System setting > Launcher style > Modern
    • Reboot required after changing style
    • Added Network connection icons to Launcher
    • RCU hotkey now active.
    • Program hotkey action from new Hotkey app
    • Classic Launcher: Manager > Hotkey
    • Modern Launcher: Home > DVB > Hotkey
    • Added IP Service scan.
    • m3u files can be scanned into the DVB service list
    • m3u can be located online or on a USB
    • USB m3u path: \m3u\<filename>.m3u
    • Close all background apps more easily
    • Hold MENU key until the task manager appears. Press the RED key to close all apps.
    • Direct import of lamedb (E2) channel list format
    • Put the lamedb file on USB and import from the STB data management menu
    • Improved HDR performance
    • Added HDR PiP, clearer HDR picture quality
    • Improved timezone selection interface and fixed timezone bugs
    • Support for Widevine Level3 added.
    • General bug fixes and performance improvements
    • MYTVOnline App updated to v1.8.8
    Formuler.tv
  • Info:
    The official firmware release (fw 1.5.0 and MYTVOnline 1.8.0) for S Series has been delayed by 1 week due to some more QS- quality control testing which is necessary. Waiting will be reward with many new futures, bugfixes and improvements. The new FW will come in 1th December week 4-8.12.
    One of new futures is new S-Series Launcher, please check the video.
  • The long awaited FW 1.5.0 for S-Series is now available over OTA.
    Updates 06.12.2017
    Update procedure:
    Change Log:
    • MYTVOnline updated to v1.8.8
  • New Formuler S Series OFFICIAL Software is available for download now.
    Software v1.5.2 can be downloaded from the Software Download menu.
    Below are the final release notes.
    Change Log 1.5.2 (r12500):
    • Added ability to start/stop Samba Share DaemonAccess from Android [lexicon]Settings[/lexicon]
    • Default apps now shown in the favorite apps section by default.
    Software v1.6.0 can be downloaded from the Software Download menu.
    Change Log 1.6.0 (r13606):
    Extended Info.
  • Updates 26.06.2018
    Update procedure:
    Release Notes:
    Formuler.tv
  • MYTVOnline version 1.9.44
    Applicable models: All S-series devices
    MYTVOnline hotfix version 1.9.44 is ready for download.
    A number of bug fixes and feature requests have been applied to this update.
    The new version can be downloaded from the Market or the new Software Download app.
    Release Notes:
    • Additional patches made to 'Stuck-in-Standby' issue
    • Fixed app crash issue with certain portals
    • Improved appearance of VOD subtitles when only one subtitle is present. (White color font is now displayed.)
    • Fixed "Can't record this stream" issue
    • Delayed auto-shutdown until in-progress Recording is completed
    • Remember subtitle preferences per-channel
    • Improved Lithuanian translation
  • Updates 26.11.2018
    Update procedure:
    Release Notes:
    • M3U supported
