Sorting favorites channels
  • Hit "OK" button then hit "RED" button , this will allow you to sort channels in Favorites Alphabetically, OR by User Defined...If User is selected they are put in the "ORDER" when you added them. If you want the "Order" so you always have your favorite channels at the top of the guide, you have to "MANUALLY" change the order when you add them.
    Hope this helps.
  • Update. - figured it out
    Go to a show that is on your favorite. click info and then click the down arrow. You will 2 channels and egg and number of other items below the line.
    Select channels and it will show your favorite channels. Now you will see that RED has triangle which means sort. Click red and it will show some sorting options. Select -A-Z
    -------------- old comment below ------
    Does not work for me.
    I tried it on the EPG guide itself - clicking ok takes me to the selected program.
    Hitting red moves on the guide moved to prev day.
    So then I tried manage favorites. Pressing long okay lets me rename or delete favorites or move it. Hitting short okay takes me to add channel and hitting red does nothing.
    I can move a particular channel’s location up
    or down but not sort. Tried hitting red in several Screens
    I have the latest mol3
    Edited once, last by sanjay.radia (December 4, 2023 at 9:44 AM).
