- Model: Z11 Pro Max
- Retail Box or Provider Box: Retail Box
- Firmware version: 11.2.6
- MYTVOnline 3 version: 11.2.4-3538
- Connection with provider: Stalker portal
- Box connected with: Ethernet / Gigabit
- Did you factory reset your device? and when?: No
- Picture url (only https): No
- Video download url (only https): No
- What issue(s) are you having? Audio 5.1 output consistency, please see below for details
- What was you expecting to happen? On restart consistent 5.1 audio
- What happened instead? Audio changes on reboot, please see below for details
- How can we reproduce the issue you are having? I am able to re-produce this issue, please see below for details
- What have you tried if anything to rectify the issue? I swapped HDMI cables, I have also changed Denon ports. No change in results.
Details:
I want to say a big thanks to JumpingRabbit, LordZeno, Sam and many others for their previous suggestions and help. After a lot of playing around with settings, I think I've narrowed down something that I hope the experts here can help me better understand.
I have the Formuler Z11 Pro Max connected via HDMI to a Denon S960. The same Denon S960H is then connected also via HDMI to my Sony Bravia (eARC).
When I turn on the Z11 and its playing a Live TV show, I check the INFO button on my Denon I see signal PCM with sound set at Dolby Audio - Dolby Surround. The sound is ok but not great. This is based on using the MOVIE remote control of my Denon to select this sound mode. More importantly I see only FL and FR for the 2 active speakers input signal, the other speakers are not enabled. I have a 5.1 speaker setup.
Formuler Z11 audio settings as follows:
Settings \ Device Preferences \ Display & Sound \ Advanced Sound Settings. All options are listed as support formats (Dolby Atmos, DD, DTS, etc.) they are grey but all enabled.
If I then go into Settings \ Device Preferences \ Developer Options \ Audio I have the following:
HDMI Output = Auto
Playback Effect = Off
HDMI Rx Adui Format = RAW
Force SD Audio = Enabled
Audi In = HDMI
The issue is the 2 channel input signal as mentioned before. If I exit MOL3, hit INFO on Denon remote I still only see PCM with sound as "Dolby Audio - Dolby Surround" and only the 2 active speakers FR/FL for input signal.
Now here's where things get interesting. I then open YouTube in my Z11 and play a "5.1 Dolby Surround Test" video. I hear each speaker report back audio correctly, the sound is awesome. I click the Denon remote "INFO" and boom now I see signal still as PCM (that's fine) but SOUND shows "Multi In + DSur". More importantly all 5.1 speakers are enabled (FL/FR/C/LFE/SL/SR) still showing Multi-in + DSur on my Denon display. The sound is great !
I then exit YouTube, fire up MOL3 and the same TV channel that previously only played FR/FL speakers now plays as "Multi-In + DSur", a 5.1 speakers working very nicely. Other channels are the same, all good !
The problem. If I turn off the Denon, TV and Z11 (I use a Harmony remote) and then turn it back on later it auto loads MOL3 and I'm back to only FR/FL input signal, 2 speakers. If I do the YouTube thing again that somehow triggers the input signal, I get the 5.1 speakers all back. All good again.
Is this expected or am I just stupid ? Ideally I want to leave the input signal as 5.1 on all the time. I suppose I can just not turn off the Z11 (btw I use 'standby' for the Z11 power mode). Thanks !
bonggo ![]()
** Update - This worked 2-3 times (shutting off the Denon/TV/Z11) but then failed. I fired up Kodi, within the Z11, to trigger a DTS movie, which played fine 5.1 speakers. I switched back to MOL3, worked. So it does seem inconsistent to re-produce.
*** Update 2 - Sorry forgot to add, I do have the Audio Optimizer installed.
