Sorry if that question was already asked somewhere but I didn't find it anywhere.
I bought a Formuler Z11 Pro Max that came with GTV-BT1 remote.
I know about the remote app, and STB mode is correctly working with my TV. I want to setup the sound on the BT mode to work with my Klipsch speakers, but it don't seem to work with the app, although it's setup correctly and Klipsch uses the same IR code for all their devices (according to their doc) so it's not my speakers that uses a different IR code. Is it something I'm missing there ? The remote is correctly sending an IR code, I checked using my phone camera and the IR light is visible when pressing the volume buttons, but it seems like the code is incorrect and my speakers don't react.
Ideally I would also want to setup a button at the bottom of the remote so I could switch my speakers off and on.
Additionally, I would want to reprogram a button to change HDMI source without the need to switch mode: holding 3 seconds, pressing source, then holding 3 seconds again, that's too much work, I just want to setup the "Source" button at the bottom of the remote to always change sources regardless of the remote mode. (or another button, I don't really care, but the best would be the one already labelled)
All those issue could be resolved by switching the remote to learning mode, and make it learn the correct IR code I want it to send, which is what I did with my previous remote.
I searched extensively online but I seems like the GTV-BT1 can only be programmed using the app, which can't do what I want. I know that the BT mode can act as hybrid between IR and BT on certains buttons, as it's what it's doing when the volume button are set up.
Does someone here have some ideas at what I could do ? Or link me the documentation about it ?
