I have 2 Z11 models, the Pro version and the Pro Max model. On the Pro Max model, I didn't have any problems with installing the applications, however on the Pro model, after installing the Apple TV software, the login window appears and when I choose to log in, the application closes. Any solution for this problem?
Z11 Pro cannot login Apple Tv
- Z11 Pro-BT1
- Apps
AderNev -
January 8, 2024 at 3:10 AM
The same problem for me... I have a Z11 Pro and a Z10 Pro Max and I cannot log in to Apple TV at Z11 Pro...Z10 Pro Max is OK… obviously it is a problem exclusive to the Z11 Pro... please provide a quick solution... thank you
I have been using the Apple TV App on my Z11 Pro Max without any problem, then this week it stopped. Would not play anything. I tried to reset. No joy. Uninstalled and tried to reinstall but I cannot log in. Just goes back to main Formuler menu. I have the App working on another TV through a Firestick.
I will have a look today.
Maby only you need the newest version or so.
Which version you have?
Apple TV Version 14.1.0
Formuler Firmware Version 11.2.10 Official
Maby this version it not good enough.
maby go nack to older version?
try search for older version en try that? Maby that one works well.
Or wait for newer version. But can be weeks.
I send you conversation. So you can try the next step😃
Let us know it helped.
I am experiencing same issue, AppleTV v. 14.1.0, Formuler Z11 Pro Max, latest firmware. Was not working on previous official firmware (11.2.10) as well...
