Hello Dears,
I just ordered my Z11 Pro Max, and I had couple of questions:
- Can I add more than 1 server provider?
- I do have my own provider EPG, yet I do have my own EPG that I created, can I use both at the same time since they cover different channels?
- does MyTVo3 support adding xml.gz?
- can I add the epg to XC or must me m3u?
- if a live channel has different audio's can I pick different audio or the option doesn't exists?
Thank you!
