When looking at a channel,the text is set to OFF,still it ON when I record the same channel.How do I get rid of it?
Text in recordings
- Z11 Pro MAX
- MYTVOnline3
Stromma -
April 15, 2024 at 11:23 AM
What text do you mean and how do you set text to OFF?
Turn subtitle off.
SAM,on the bottom of the screen there is a button, "settings", behind it there are "subtitles" and you can choose: OFF/ON, "closed subtitle" or "reset". There, subtitles are set to OFF, so no text while I'm watching live but text when i record!
Check also Settings from MOL3 Menu -> Settings and turn off their too, test again.
I found something about "text" in "accessibility" but it was off there too ,and I still have teletext when I record!
So you see the captions even if you set the player not to see them at all or are they just present if you choose to see them? Because I think they just might come together with the video when you record it (if the given program/channel offers them) and then you can choose to see them or not. My recordings (when my Z11 bothers to make them) come usually (if that is the case of the respective program) with more than one subtitles/text: closed captions, DVB subtitles etc..
This looks for me like some extra info from channel but doesn`t explain why it doesn`t happen in live tv. Does this happen on other channels to or on specific channels?
I get this type of text from time to time on CNN.
I have only record from Fox sport 1 and 2. If I record and watch live at the same time,there is text in the recording but no text live.
I s the text you are seeing related to the program you are watching,or is it just random text?
From your picture in post#6 it appears to be related to the car race,maybe what your seeing is so called "audiodescription",used by people with a hearing disability.
