Hi, I get a an 'inactive' popup and if I don't click exit or ok it shuts it down, this isn't helpful when recording. Is this a setting in MYTVONLINE or the box, either way where is the setting to adjust or preferably turn this off.
Thanks In advance.
Inactive Time Out.
- Miscellaneous
- S-Turbo
Dirty Dog -
December 29, 2017 at 9:45 AM -
Dvb [lexicon]settings[/lexicon] -Eco Mode on?
No it's 1turned off.
Can you upload picture from pop up window, im not near stb box.
Next time it happens I'll get a picture.
It happened when I was recording, not sure if that makes a difference.
The box goes into standby if left on overnight. -
Happens after 2hrs...
See attachment
Can't see how to insert image...
Copy Attachment link and press icon picture, insert the url and ok
Could you please check the sleep function?
Mytvonline -> Red Button, then scroll to sleep menu. -
It's OFF
What is the latest app version please.
Website says 1.8.6 my version shows v1.08.08-r1378Previous version had inactive error bug?
How do I check and update the app?
Inactivity Standby Mode bug fixed in 1.8.6 and 1.8.8 is also running on my box since 1.5.2 fw update. The newer 1.8.12 is at moment not online because of maintenance on OTA Update server since last problems with bricked boxes.
Ok Thanks.
Shame they don't add an option to turn the Inactivity Standby Mode off, makes setting a recording worthless.
There needs to be a series link as well so you can record a series with just one click. -
Something else, did you done already factory reset after 1.5.0 or 1.5.2 Update?
No I haven't, what the process and files required for this please.
