Z11 Pro Max - set up
  • Hi all, My newly ordered upgrade from the Z8 to a Z11 Pro Max arrives in a few days and I will be setting it up.
    Any advice, other than connectiong to my provider through a portal etc, that I need to set up?
    Dont worry,basically the Z11 is plug and play (&enjoy).
    In Homepage there is a Helpcenter where many instruction videotutorials are available,any other issues can be .
    solved by reading the Formuler Helpdesk (Quick Guide etc).Any other questions you encounter can be put forward on the forum,after doing an initial search,that may already answer any questions you have:smiling_face:
