How to factory reset Z mini
  • Just , I was wondering how to do a hard reset on the Z mini ? :thinking_face:
  • Hi,
    1. Software reset:
    Home menu -> Settings -> Device Preferences -> Factory reset.
    2. Hardware reset:
    On z mini you have one small button.
    • Disconnect power from Z mini
    • Connect power to z mini and press instantly the small button and hold, until this Message appear.
    • One single press on button moves down through menu. Longer press opens the menu.
    • After successful reset chose "Reboot system now"
  • Thank you, I haven't needed it yet, the Z mini works perfectly :OK_hand:
