Just reporting a bug in the newish MTVOL2 beta, everything works fine eg: afr etc.. however when in the guide (guide button) you scroll through channels and at an early point the app throws you out , if you scroll through channels within the guide slowly it holds up, but on normal and faster speeds it throws you out, can't roll back after beta so any advice? Thanks![]()
