How to get 60hz on my samsung tv
  • Hey! I have samsung tv TQ55QN95CATXXC and soundbar samsung MS650.
    I know that my Z11 pro will work with 4k and 60hz.
    And my tv has up to 144hz.
    100-120hz normal.
    I have talk with samsung and they said that i just have to change HDMI 2.1 cabel to mabye a different ( hdmi 2, 3, 4 ).
    I have my HDMI 2.1 in HDMI 1 now.
    I have 50hz on my tv right no but i wanna have 60h.
    Can i force my tv and Z11 pro to do it?
    I will put a HDMI 2.1 from my soundbar to my tv i ARC.
    Please help 😅
  • I think you need to connect your soundbar to HDMI 3 for ARC. Don't know this model, but on Samsung is standard. Then you can connect your Formuler to HDMI 1, 2 or 4. Also set HDMI signal plus on, it gives you more options about frequency, color space etc. And if you just set your Formuler to Auto resolution, it should display 4k60hz. You can also manually select from the Formuler settings menu
  • I think you can try first with the cable you already have. Some models Samsung have only HDMI 4 as 2.1 and is ment for game console or PC. But try to enable HDMI signal plus from your TV and use HDMI 3 for ARC
