Hello
I would like to understand if using formuler z11 pro max with mytvonline 3 allows me to watch channels with translations to English via subtittles ?
Is it free ?
And if so which languages are available for translations ?
Thanks Amit
Hello
Is it free ?
Thanks Amit
Hi,please read in Article section on Homepage formuler-support the article"How to download online subtitles and use this in mol2"![]()
I saw it now.
If I understood right it translate a show/movie from French to German language.
I'm interesting in translation to English simultaneously for on-line channels not for movies.
Does formuler z11 and mytvonline allows it for free ?
Actually,i dont know,as i never use subtitles(find them annoying!)
Best to do is test it out![]()
I don't have the streamer yet
I would like to know from someone that used it this way...
Depends all from your provider, if channel suport subtitles and deliver this in stream, you will be able to activate and see them.
By "deliver this in stream" you mean that there is an option that the channel deliver it in stream but I don't see it unless I activate them ?
And if soo, it will let me translate it to English?
Hi,SAM,
On the topic of subtitles,i have some UK channels that show english subtitles during tv shows.
How do i disable these "useless" subtitles?
Edit problem solved press red button>subtitles>turn off
When you buy the box, you will be able in settings to activate MOL3 language and subtitles, on each channel you can also set with or without subtitle. If available in English then you will be also able to use English. The subtitles availability depends from provider and not from the Box.
I understand, so the option for translation to English via subtittles depends on availability of the channel and not on the box
Correct.
